Using an old Xbox 360 with a modern TV
bwana
MyBroadband
Super Moderator
Plz
The kids found an old Xbox 360 of mine in the cupboard and want to use it. Unfortunately all of our TVs are HDMI and the Xbox uses Component YPbPr or AV - what are my options?
Build a time machine to 2007?
Assuming it's the launch 360 with the component cables. Does Takealot etc. not have adaptors?
I'm sure the classic video game hoarders collectors will be here shortly to advise
Could try
Check this out on takealot: AV/CVBS To HDMI Converter
Could try
I've added something similar to my Temu basket. For some reason I've got it stuck in my head that Component would be better.
Component would be better as it would be HD, could try see if you can find the VGA adapter
Nice - and then a VGA to HDMI adapter.
To convert to HDMI I would recommend looking for
If you el chepo
Else check out for an OSSC
There is diff variants and prices online.
And if you really rolling in $$$
Retrotink 4K is the best:
