using route sentry and ICS to share 2x connections?
headstrong
Hi
Can I use route sentry to split traffic between 2 adsl accounts but still share both connections??
I want 2 share my internet with my network but I want to still be able to use a local only account...
You can do this by installing a proxy on your PC with the internet connection and have the other PCs connect to the net via this proxy. You could try installing my free DDProxy app to do this. Do a search on myadsl for ddproxy for more info on configuring it for email etc.
Hi there
I can second the above. That what we do in our offices and it works like a charm. No hassles. A little bit of setup owrk, but if you ask for help from Antibody via email or he will respond and you will be sorted out.
ok kwl! sounds easy enough!
But would other online applications still work? Like local gaming etc?
