VALR to Binance help
zubheir
I have a VALR account with some Btc & Eth.
Is it possible to transfer my crypto to a binance account? Reason is they have more coins to purchase that are not available on VALR.
I dont want to use eft or credit card to purchase from binance.
Is this the best cheapest way or is there something I dont know about?
All suggestions welcome.
You don't need suggestions. You need to educate yourself on how this all works.
1) Open a Binance account
2) Go to the coin you want to transfer in your Spot Wallet and select Deposit.
3) It will give you an address to send to, SPECIFIC to the type of coin you're trying to transfer. Do not send Bitcoin to an Ethereum, Polkadot, Cardano, Terra or any other address (and Vice Versa). It will disappear. Possibly forever. So Binance will give you a different address based on the type of Tokens you wish to deposit.
Now...
4) Go to your VALR wallet. Go to the coin you wish to withdraw. eg. ETH. Select Withdraw. Enter the address from your Binance Deposit page into the VALR withdrawal page. (ETH is native to the Ethereum Blockchain, so Binance will give you an ETH address to send to when you selected Deposit in Step 2. It will behind with "0x")
5) Send. VALR will probably charge you a withdrawal fee.
Now...
Thanks will do this
Change all you Btc & Etc to ripple (xrp). This has the lowest transfer fee but make sure you send it to your ripple wallet
Thanks was also wondering which is the cheapest way.
