VGA + audio to HDMI
But HDMI does carry audio signal right?
Yes. But I doubt you're not going to find such a converter. Does the tv not have a vga input? It's not that much more difficult to plug in one extra cable...
If your tv has hdmi, it should have a VGA or DVI port somewhere...
If he only has VGA out, then having a DVI port on the TV wouldn't help to make things simpler. In that case, he might as well use HDMI
S-video carries video as two separate signals, luminance and chroma which can give a superior picture than a composite video connection.
As sn3rd said, It does not carry audio.
