Vipleague.ws Adblocker issue
getafix33
Howdy.
Been trying to access vipleague for the past few weeks and cannot stop the adblocker popup.
Basically it says I have adblocker installed and wont let me proceed. I dont have adblock installed at all.
Have also tried at work where adblocker is installed and have created exceptions but still I get block.
Have also tried different browsers.
Cheerz
Do the ads and popups happen? If no then something is blocking them and you need to figure out what. Try clear temporary internet files. Your operating system or service provider could be blocking the content.
What browser do you use?
I do have add block on chrome but its easy to make that popup disappear.
Right click "Inspect Element" click on the highlighted element and press delete...tada!
Use Chrome.
Tried inspect element and a whole bunch of stuff (coding etc) appeared at the bottom of the screen. Nothing happens when pressing delete.
OK, worked it out - thanks
