general_koffi
Hey
I recently got Windows Vista Ultimate 32-bit.
I'm having some problems with the networking, though... I connect to the internet with ADSL and a Telkom router in router mode, right. With XP, this setup works 100% when I manually set the IP, subnet, DNS etc.
But in Vista, the computer seems to have trouble connecting to the LAN. The connection icon has the little yellow exclamation over it, and it says "limited connectivity" in the network centre.
The problem is very random. It doesn't seem to make a difference whether I do the network settings manually, whether I set it to auto, whether I enable or disable IPv6 (still don't know how that setup works) etc... It will sit with "limited connectivity" for minutes at a time before it will randomly be able to connect to the LAN and the internet. Sometimes I have to reset the router before it will do anything. Using the diagnose feature Vista has has been fruitless.
Any ideas?
Any ideas?
