New2Broadband
Hi, please can someone help? I just bought a new laptop which comes with Vista preploaded (hmmmm), anyway I downloaded the HUGE VMC 9.1.1.5142 installation file. It installed okay but then I try and use it I get an error message "Buffer underrun detected....". The error message simply offers the option of terminating the program, however, what can happen at times is that I notice I am actually connected although there are no indications on the dashboard that I have a connection running. Therefore, what's the point of having all the frills and fancies of the program (including sms support, which doesn't work)?
With that in mind I discovered v9.2.1.6545 on the Vodacom site which I downloaded. Another HUGE file. I uninstalled v9.1x before attempting to install v9.2x. Oh my gosh! This v won't even install at all. During the file copy proccess of the installation it gives me an error:
"Error 1309. Error reading from file: .....\Vodafone\Vodafone Mobile Connect\Bin\SMS\SMS.exe. Check that the file exists and you can access it."
If I select "ignore" I get similar errors with a whole stack of files.
Is there something on my laptop which might be preventing the installation (although installing other software has been 100%), or what?
HELP! (please)
Have electricity - will surf
HELP! (please)
