BBSA
- Jul 11, 2005
- Location
- People's Republic of South Africa
Thanks, will give it a go.I had similar issue in mtn on B618, same model 22D
I switched router it fixed problem.
Also try connect 4g only force and not 4g+. in band tool select 1800mhz only. Might help.
It is actually a very nice app, it is also able to change your LTE band.BTW, I found an app to view the current band
Correct, but not to bad considering I live in a rural area.your RSRP is weak and SINR @BBSA
You are lucky.i also live in the country side but i get Insanely Fast speeds 1800mhz vodacom
