iEverything
- Jan 2, 2009
Hi,
I am looking to get this router to replace my existing Huawei B683 which I have been pretty happy with but want LTE speeds.
I have downloaded the quick start manual and scoured the usual sites but the following is still unknown to me:
- Do the Ethernet LAN ports support 1000mb or just 100mb?
- Is there a WAN Ethernet port like my B683, reason I need this is that my Airport Extreme does the DHCP and just want to bridge the B2000 and the Extreme
- If you procure through Vodacom is it network locked?
