Is the modem device appearing in your device manager, or only the virtual CD-ROM? The device needs to be 'modeswitch'-ed in order for the modem device and COM ports to appear. Try running VMB first to kick it into the correct mode, and then make sure VMB is properly closed and no other dashboards are running before you try the firmware upgrade.Downloaded the drivers from www.dc-files.com and installed, but still getting the same error... I'll just scratch around a bit. I'm sure I'll figure it out![]()
Ah, thank you sir! You are a mentor, and a visionary! Now for the password... How do I get that?
Technically, Vodacom should be able to give you the flash code, but I can just imagine how that call to the helpdesk will go.Ah, thank you sir! You are a mentor, and a visionary! Now for the password... How do I get that?
"He? Femwe?"
Not connecting to what?The K4605 is not connecting at this point. I'm hoping that once the firmware has been upgraded, it will be fine.
I'd like to know this too, you are risking your warranty for what?What is to be gained by flashing the K4605 to a E372?
