I don't know the IPs because it isn't publicly available for fifa,I have a call scheduled with my isp today so hopefully there's a fix for this find it abit strange that I've suddenly been sent to the EU server,thanks for your hel
While your ISP does have some control over routing, you need to keep in mind that the game client is the one that makes the final call. Your ISP can bend over backwards but if the client does not want to play ball, there is nothing that can be done.
Cannot hurt to reach out to your ISP though, although I suspect that they will want some details from you (if they are even willing to assist). Do you know what the IPs are that you are trying to connect to even?
Ive also come across this isp that vuma seems to promote on their Twitter
https://urbanx.co.za this isp has a ping test on their site which also shows Europe for the eafc server so I wonder what's going on
