techead
hi guys
ive been looking at installing a water cooling solution into my case. I have the original gigabyte aurora full tower, so I dont think space is going to be a problem
regarding what solution to use is proving to be a problem though. Im looking for a solution where I can cool both my CPU and VGA in one shot! It seems to be possible, but many options only cater for CPU which I think is DAFT!
Reason Im doing this is quite simple. My room is really small, and has like ZERO airflow and it gets so hot when I use my PC... and I use it a lot
Im running an Intel E8200 and ATI 4870.
I move my PC around quite a bit, so the Zalman fanless cooling solutions arent going to cut it... they HUGE and have to carry them all over. Im looking for something that could be internal, or something that can clip on the back of my case, like ..
http://www.driverheaven.net/reviews/gigabyteWCdec06/index.php
I think this might be my best option, but Im not sure. Anyone able to offer me some advice? Would I be able to hook up both VGA & CPU with this one above?? I think so!!
thanks guys, any help is much appreciated
