P
Picard
Guest
So is the American SPIN engine ... which is a full scale degree program at all leading US tertiary institutions.
Dihydrogen monoxide:
is called "hydroxyl acid", the substance is the major component of acid rain.
contributes to the "greenhouse effect".
may cause severe burns.
is fatal if inhaled.
contributes to the erosion of our natural landscape.
accelerates corrosion and rusting of many metals.
may cause electrical failures and decreased effectiveness of automobile brakes.
has been found in excised tumors of terminal cancer patients.
Despite the danger, dihydrogen monoxide is often used:
as an industrial solvent and coolant.
in nuclear power plants.
in the production of Styrofoam.
as a fire retardant.
in many forms of cruel animal research.
in the distribution of pesticides. Even after washing, produce remains contaminated by this chemical.
as an additive in certain "junk-foods" and other food products.
What are some of the dangers associated with DHMO?
Each year, Dihydrogen Monoxide is a known causative component in many thousands of deaths and is a major contributor to millions upon millions of dollars in damage to property and the environment. Some of the known perils of Dihydrogen Monoxide are:
- Death due to accidental inhalation of DHMO, even in small quantities.
- Prolonged exposure to solid DHMO causes severe tissue damage.
- Excessive ingestion produces a number of unpleasant though not typically life-threatening side-effects.
- DHMO is a major component of acid rain.
- Gaseous DHMO can cause severe burns.
- Contributes to soil erosion.
- Leads to corrosion and oxidation of many metals.
- Contamination of electrical systems often causes short-circuits.
- Exposure decreases effectiveness of automobile brakes.
- Found in biopsies of pre-cancerous tumors and lesions.
- Given to vicious dogs involved in recent deadly attacks.
- Often associated with killer cyclones in the U.S. Midwest and elsewhere, and in hurricanes including deadly storms in Florida, New Orleans and other areas of the southeastern U.S.
- Thermal variations in DHMO are a suspected contributor to the El Nino weather effect
