Web site access problem - Solved
Piesang
In a Android close to Cape Town
Can anyone who uses CellC internet try and access the following webpage:
www.miglio.co.za
I get the following error:
Directory Listing Denied
This Virtual Directory does not allow contents to be listed.
We've been using it all the time but now since I got the CellC deal I can't.
I get the same message on Axxess ADSL so doesn't look like a Cell C issue.
using mtn & get the same error your seeing
www.miglio.co.za
Got the same issue using MWEB business.
Doesnt really matter which ISP you're using anyways, some dumbass has either deleted his default index.htm(l) page - MOST likely.
Or
That site has been hacked.
The error indicated that no default document for that site is available or defined for the / virtual directory, and it (correctly) won't show you a directly listing of all the files available.
www.miglio.co.za (cant access) points to 196.3.165.10 (you get driectory listing when visiting IP only)
It also reverse dns to millers.datapro.co.za ---> Millers is up and runnning.
