WeChat signup issue on Telkom Mobile
Alkine
I'm having issues signing up with WeChat on telkom. For some reason instead of sending me an SMS code like most apps, WeChat asks me to send a code to this number: +27872406742. Only issue is that the sms fails to deliver. It works fine on other networks. Telkom has been less than helpful to say the least.
I have two questions:
1. Can anyone on Telkom mobile test if they have the same issue.
2. Is there a way to use the assist a friend functionality in WeChat to help me sign up.
Help will be much appreciated. I signed up for a multi park cycle pass and it uses WeChat for some reason. :(
Also cannot sign up with vodacom, need another wechat user to verify you.
They really do make it hard to join!
I've contacted WeChat support as well - multiple times - and have not had any response.
Hi there
I just came across this thread. I am with Telkom Mobile and I am having a lot of trouble signing in to my much needed Wechat account for the exact same reason! Have you had any luck figuring out what to do to fix it? Any help will be appreciated as I literally do not know where to next!
I doubt they will be able to help . Since it’s a 3rd party application.
Your best bet is finding someone in China to verify you . That’s what I eventually did
I landed here because I am having problems with wechat, I am on Telkom Mobile too.
