AchmatK
I have a 2011 Citroen C4 THP and started having some aircon issues. It has a dual zone climate control.
First issue is that the aircon would randomly not come on. Neither the fan or compressor. It usually works first thing in the morning but if I switch off the car and restart it, the aircon would not come back on.
Second issue, when it does work, the driver side does not heat up when the temp is set high. Only the passenger side heats up. Even with the recirculate mode off, the driver side still does not get any heat.
The cold setting does work, only the heat setting that doesn't work and only on the driver side.
I've had it checked for gas and it's still full. CT mornings are getting cold and need the heat to demist the windscreen in the morning, especially when it rains. At least I have heated seats to keep me a bit warm.
Any one know of a good aircon guy in CT that can have a look. Also cannot afford to have the car in a workshop overnight.
