What’s wrong with my plants
RoastClash
Hey, I’ve just transplanted 4 plants from solo cups to their 2 Gallon Air Pots. I have them running on 600w MH lights right now, hung at about 24” from plant tops at 100% lumens. These plants 2 weeks exactly from sprout. I’ve noticed two of them have some slight lime green to yellow on the inside and the other two (Ive noticed even before transplant) have some of their leaf blades curled upwards.
Is this cause of the light being too hot (I’ve moved it up from 18” to 24” and the whole leaves aren’t coneing) Or from a nitrogen diffenciancy? I water at a 6-6.5PH but the run off (Using Happy Frog cut with Perlite 2/1) is about 4-4.5.
If this is because of PH what can I do to adjust for my soil changing the PH. If not, just what can I do to fix this all.
What is your soil mix?
Wha tis you rfeeding schedule and which nutes are you using?
This should be moved to the cannabis growing thread.
