What App for using iPhone as remote Control for PowerPoint on iPAD
DeonH
Hi there.
I have bought Quickoffice Pro HD to use for presentations. I just plugin the VGA adaptor to my iPAD to use the iPAD with our data projector. I know there are Apps that "changes" an iPhone to a remote control to use together with presentation on an iPAD. I have bought "Pointer" but cannot get the phone and iPad connected with one another.
Your suggestions will be very welcome.
Regards,
Deon
Hi there.
Regards,
Deon
It's called Keynote Remote. But it is designed to work with Keynote, not Quickoffice Pro HD
This is one of my favourite apps
Rowmote controls Front Row, Airfoil Video, Adobe Lightroom 2 or later, Amarra, Aperture, Boxee, DVD Player. Ecoute, eyeTV, Firefox, Hulu Desktop, iPhoto, iStopMotion, iTunes, Keynote ’08 and ‘09, kJams Pro, Last.fm, Logic Pro, Movist, mPlayer, OpenOffice Impress, PandoraBoy, PandoraJam, PandoraOne Desktop, Plex, Powerpoint 2004 and later, Preview, Rdio, Quicktime, Safari, Skim, Songbird, Spotify, The Tube, VLC, and XBMC.
http://regularrateandrhythm.com/apps/rowmote-pro/
EDIT - nevermind - the above app is for controlling a computer. :o
Thanx for both replies.
I have keynote but it does not seem that I can import finished presentations to keynote?
I will check out Logicinmind. So far I have seen that I need a local wifi but also with hotspot. I will check it out.
Regards,
Deon
