Cassady
- Oct 27, 2011
Hello all,
I've just signed up for Fibre, after several years of WISP. The latter saw a dish up on the roof, and WAN cable down to a POE, and into my Asus Router.
OpenServe is hopefully coming on Wednesday, to set-up the Fibre connection.
From what I gather, the Junction and ONT box is what will be "added" to the mix, by the Openserve installation.
Since I won't unfortunately be at home during the install, I'm trying to get a sense of what I need to tell the SO, in terms of what should happen in the install.
We have also just finished painting/touching up inside and outside – so trying to minimise any 'invasive' changes!
I have a couple of questions that I am hoping someone who has recently installed Fibre can help with:
1.) How should we expect the fibre cable to brought 'into' the house?
As in – do they drill entry-points through the wall etc? If not, what then? And how is the placement of the cabling actually handled?
The current Router sits in a fairly visible area in the middle of the house, at the bottom of the stairs.
As in, the main area of the house is "below" the road level, with only a main bedroom/study and bathroom being 'upstairs' at the road level.
So any cable brought in, is going to be fairly visible?
Do they take care of any cable trunking – or is all the cosmetic 'fixes' for our account?
2.) Must the Junction and ONT be affixed to a wall? Or can it be placed inside a cabinet etc.?
3.) Am I correct in presuming that we could have the Junction & ONT installed on the upper level, and then make a plan to run the WAN/Ethernet from the ONT downstairs to the Wifi Router?
So there aren't necessarily any benefits to having the Junction/ONT next to the Router?
Any other pointers I might have regarding the practicalities surrounding the practicalities would be appreciated!
