They do send you warning e-mails...once when you hit the 50% mark and the when you reach the 95% mark.After your cap you pay like you won't believe: R1 per MB. And you do not get switched off either; you just move onto that ridiculous rate.
Im not so sure if should believe all of this because they didnt even put it on their
web sight i mean really....![]()
I exceeded the cap by a gig, without realising last month - just to find an additional R1000 added to the billI have never received one of these warning e-mails.... So tread carefully!
At least now with a 20gig cap its a little better..
Sentech's capping system is TERRIBLE and full of problems so beware![]()
This how it works.Say you're on the 1 Gig option, Sentech will allocate an extra 400M that you'll start using once you hit your 1Gig cap.But that 400M is not for free.You'll be charged 1R/M.Lets say you continue using the extra 400M and you finish all of it , you then get cut off the network.You bill will then have (your monthly installment for your package) + R400 randsid like to know what sentech plans to do after cap are they going to do like iburst or what?
Some of us who had no choiceGuys why are we talking about flexi packages, who would take these contracts?????
I know.I used to be on the 256 package and was hitting 30G every monthAnyway there's no cap for the classic packages, I hit 15gig on my 128 package and didn't get nailed for the extra gigs.
@ the risk of sounding blond - why not choose iburst or uninet? Why pray tell why?
I never had any major bad experiences with Sentech.Also I didnt want to go through another round of the expensive process of initial setup...either with IBurst or UniNet.
Besides , at the moment sentech are offering the lowest cost per M of data
Im on the MyWireless flexi10000plus and now have a 20 gig cap, its not too hard getting used to only 20gigs a month...
As far as speed goes the upgrade is amazing, im getting over 1mbps consistently
Im downloading torrents at an average speed of 150-200 KB/s (and that's over the last 20 hours)
For the first time in a long time, im a happy customer![]()
Flexi 1000...the one with the 2G limitOk cool, so what package r u on?
Do u miss the 30 gig downloads?
