What Is Wrong With My Onboard Sound?
Edwe
For about two months now, I have been using GuitarFX 3 on my PC as a guitar amp. I plug my guitar into my line-in jack and output to four speaker via my lines-out.
Since about an hour ago, I have been getting subsonic rumbling and clicking/popping on my front speakers and on my headphones, as well as abnormally high CPU usage, while playing. I have also noticed that, even after stopping Guitar FX and muting all input audio lines, I can still hear buzzing and rumbling when I strum my guitar strings. Also when playing songs I have created in FL Studio 5, I now constantly get audio buffer overruns, which I have never had before.
I am using SoundMax integrated audio on a 5 year old Intel motherboard. I have not recently changed my hardware configuration nor have I changed any software settings, except for muting and unmuting audio lines.
Has anyone ever experienced something similar? Is my motherboard dying? :(
EDIT: Yes, I have checked that all audio jacks are firmly connected and that there are no hardware IRQ conflicts ;)
Is there any way you could borrow a soundcard from someone and try and see if there is a difference? Maybe it is only the sound "chipset?" that got damaged on the MB.
Well you might as well get a soundcard if you are planning to record and play through it.
I also play guitar through my PC, and record stuff often. A new soundcard really helped with getting rid of alot of that crackled and improving the sound.
I'm getting a new PC with a Creative X-Fi XtremeMusic on 1 February, but I need to live with this rubbish until then. Thanks for the advice, Ekhaatvensters.
are you guys all using asio drivers, or asio4all, to get rid of the latency?
halicon said:
stupid suggestion but worth a try - mute anything you do not need. ie - Mic in, MIDI, ect ect.
Not a stupid suggestion, except for the fact that I've already tried it, as stated in my original post. ;)
The strangest thing is, I still hear this rumbling noise after muting the master volume and only on the front speakers and headphones. It's definitely not the speakers, since I have tried swapping the front and rear speakers :confused:
have tried muting all output levels? another stupid suggestion :p
the reason why i ask is once i had a funny his noise with an old yamaha s/c and only when i muted MIDI output did it stop.
mind you it was a crap card.
