Yes I know, will 20mb be stable, is my only concernIt's telling you your potential max line speed in the pic...
No prob, just remember you always want high noise margin and low attenuation. Your values are both good! They should change once you upgrade. Your stats tell me your line NEVER desyncs, is that correct?Thanks guys, asking axxess to increase to 20mb
Lines was broken for more than a year and last week openserve fixed it and yesterday the tech came to reconnect, so since yesterday noNo prob, just remember you always want high noise margin and low attenuation. Your values are both good! They should change once you upgrade. Your stats tell me your line NEVER desyncs, is that correct?
What will you be buying with the big refund?Lines was broken for more than a year and last week openserve fixed it
Axxess says exchange only support 5mb I cant get 20mb do I call OpenServe.
Possible. You can have a look at Openserve.co.za also to see what the max speed is that is supported.
10mb, thought I could convince someone to increase to 20mb but no such luck
