what external wifi antenna
Grant
just around the corner
A friend of time moved to a new townhouse complex.
The complex has a fibre connection, with a few wifi repeaters around the property.
The complex did some additional building work, and now a new wall has become a barrier between the complex wifi repeater and her home.
Trustees are aware of this and intent either adding an additional repeater or re-locating a couple of them - this will only take place January next year.
She uses a MacBook Pro with it’s onboard wifi.
I’m thinking to buy an external antenna that can be positioned to connect to the closest repeater.
Problem is, I know nothing about these things.
I’m seeing usb wifi adaptors with their own proper antenna - which may improve things a little over the laptop’s internal antenna - probably only slightly.
So I’m thinking an external antenna mounted on her patio ceiling - or somewhere similar that would almost be in line of sight with the complex’s wifi repeater.
What to get ?
A bigger antenna won't solve the problem. The only way to find out is to test the Wi-Fi signal, and there are many good free apps for that. My advice is to first determine where in her living space she has the best signal and work from there. Sadly, pocket Wi‑Fi routers have become a little expensive, but they are such a charm to have.
Okay, I see there are still some reasonably well-priced travel routers. Definitely a must-have in my opinion, and if it doesn't work for her, keep it for yourself. I am not going to post options here, but a lot of brands have one now.
