How to request Outdoor CPE Antenna
YMelane
Kindly assist, how can I use the outdoor cpe antenna on my HUAWEI B315s as an external antenna. I recently bought this house and I’m struggling with LTE coverage, the house has an outdoor antenna with a small dish, it uses rj45 cable which I believe must be connected to a Poe injector. I want to use this as an external antenna but don’t know what hardware I’d need for this. Somebody please assist, I bought a lte antenna on Takealot but it is not helping with boosting the signal, I also noticed that I might be blocked from the line of sight with the nearest tower as there is a block of flats next to my house.
Going to have to share more details. link to antenna? also on the B315 you need to select the external antenna in the routers OS
Bought that same antenna from Takealot. Utterly useless. But as @DTBA said, you need to enable the external antenna in the router settings.
I ended up just getting a B618 and that sorted my problem.
Buy an antenna from these guys. They actually know what they're doing:
If you buying something get this https://www.takealot.com/dual-polar...enna-with-10-meters-cable-bundle/PLID34148767
Works wonders if you have kinda an idea where the tower is.
Got one for my B315
