sdd
I normally do noise reduction first and sharpen last ... is this correct?
Using Noise Ninja.
Using Noise Ninja.
My 400D only has Long exposure NR but I've made sure to disable that.
Time. I only generally make long exposures when I'm shooting lightning and as we both know if you take a 30 second exposure you have to wait another 30 seconds for it to take the dark frame.Why? Dark pixel subtraction does not edit pixels like High-ISO NR does.
Since noise is usually predictable I can always take a dark frame at a later stage and do it in photoshop.
If you expose your image correctly in camera your noise will be mininal or zero, that is the key.
LongExposure NR is an absolute waste of time, turn it off, it can quite easily cost you a shot while the camera is (doing a poor job) processing the image.
You can always test your sensor by taking a dark frame.I didn't know you could do thatThen again, the only time I do exposures long enough to warrant long exposure NR is when I'm taking night time cityscapes/buildings/etc where I'm not going to miss a shot while waiting. Letting the camera handle that makes more sense to me than dicking around in PS and ending up with an extra 60MB file.
Depends on your camera.
For hot pixels? Yeah. I don't know if it's consistent though - I've never had a hot pixel myself, and none of the reviews on the 40D that I have read have found any either. But it doesn't bother me to spend a little extra time to be sure. Most of my long exposures are under 5 seconds, anyway, so it doesn't eat up too much time.
Have used this function on several different camera's over the years. If you shoot raw, that function is actually meaningless anyway and you can do much better NR using the right software.
You'll probably only ever start seeing hot pixels when you run into exposures of 10 minutes and above, even the highest "flag ship" models will reveal hot pixels with very long exposures albeit slightly less than the lower end models.
What did you use to track the stars with?Did several back-to-back shots of stars - 30 minute exposures. I switched all NR off because I didn't know if the batteries would make it, it was pretty cold anyway. Didn't get a hot pixel anywhere.
This may differ from camera to camera. On the 40D, long exposure NR is applied to the RAW, but high ISO NR is applied only to JPEG. I'm not convinced about the post solutions. I haven't seen anything that's better than what I get out of my camera. I continue to try, but so far the money I spent on NR software is waisted.
I've done numerous tests with NR on and off and the differences in the final image are imo not worth that extra wait, I also get flawless results with the correct NR software.
As for the hotpixels, I did not elaborate, depends on the aperture used, very small apertures with long exposures in low light will reveal them. I have many 30+ minute exposures with not a speck.
I think I'll have to give that a go. If I was going to shoot the horizon would facing north (or south) give crescent/arc shaped trails?I didn't track the stars. I was doing star trails![]()
