Which AV software has a good speed and memory usage to effectiveness ratio?
Avast (non-paid) has worked for me. By the way I think it's time to upgrade. Antivirus resource consumption is so 2005.
I used AVG for a long time, but the advertisement banner (to buy the paid for version) in the end got on my nerves, so I switched to MSE. MSE is really unobtrusive and resource-friendly. I'd recommend it any day.
Thank you for the useful information.
I might try MSE. It looks like it doesn't include a firewall though.
I run Windows XP.
Is the firewall that comes with Windows XP any good? Should I also install a firewall?
MSSE is designed to run with windows firewall...
I run Windows XP.
Just use the Windows Firewall it is more than adequate.
If you are worried about malware getting through then as an added extra layer of security use a HOSTS file that blocks most known malware and hijack advertising....
http://winhelp2002.mvps.org/hosts.htm
