WiFi Card
rpm
Admin
Staff member
Johannesburg
Posted by: lexor
Description: Almost brand new - bought it about 3 months ago. TEW-423PI 54Mbps Wireless PCI Card cuts the wires to your desktop and provides 54Mbps speed to handle bandwidth-intensive applications. It complies with the IEEE 802.11g standard, making it backward compatible with 802.11b networks for assured compatibility. Advanced 128-bit WEP encryption is supported to provide secure access for your data. Cut the wires and move your desktop where you need it with TRENDnet´s 802.11g wireless PCI Card. FEATURES Wi-Fi Compliant with IEEE 802.11g and IEEE 802.11b Standards Uses 2.4 GHz Frequency Band, which Complies with Worldwide Requirements Supports Ad-Hoc (Peer-to-Peer) Mode or Infrastructure (AP-Client) Mode Dynamic Data Rate Scaling at 54, 48, 36, 24, 18, 12, 9 and 6Mbps for 802.11g Dynamic Data Rate Scaling at 11, 5.5, 2 and 1Mbps for 802.11b Maximum Reliability, Throughput and Connectivity with Automatic Data Rate Switching Compatible with Windows 98SE/ME/2000/XP/Vista Supports 64/128-bit WEP, WPA/WPA2 and WPA-PSK/WPA2-PSK Detachable 2dBi dipole Antenna with Reverse SMA Connector Low Interference and High Susceptibility Guarantee Reliable Performance Range of 35~100 meters indoor, 100~300 meters outdoor (depends on the environment) Simple User Setup & Diagnostics Utilities
Price: R130.00
WiFi Card
