I've got an oldish Telkom Marconi router lying around and was wondering if I can set this up on my Xbox to connect to my wireless network?
Or perhaps if someone knows of a cheaper generic to the official MS Wireless Wifi adapter.
cheers
simple, all you have to do is:
1) plug the marconi into a pc via ethernet cable for the initial setup and connect to its web interface page
2) assign the marconi an ip address that is within your range (eg if your main router's ip address is 192.168.1.1 then give the marconi an address of 192.168.1.254 or something).
3) then switch off dhcp and the firewall on the marconi.
4) then, set all the wireless properties on the marconi to be exactly the same as those on the main router, so that will be the ssid, encryption type, encryption password and radio channel.
5) plug your xbox into the marconi
6) and then you will have an uncle whom you shall refer to as bob.
