N Nees Well-Known Member Joined Oct 21, 2016 Messages 138 Reaction score 4 May 1, 2019 #1 Good morning, I need to find out if this can be used as a WiFi repeater/extender. Thank you. Attachments IMG_20190430_195528.jpg 5.9 MB · Views: 18 15566942547901164605893442104961.jpg 3.7 MB · Views: 18
Dimpie (JIGSAW) Honorary Master Joined Apr 7, 2009 Messages 15,017 Reaction score 13,251 Location Tygerdal, Goodwood, CTN May 1, 2019 #2 https://www.corenetworkz.com/2009/06/configure-d-link-dwl-2100-ap-as.html
N Nees Well-Known Member Joined Oct 21, 2016 Messages 138 Reaction score 4 May 1, 2019 #4 Is that by not using a LAN cable as I am using my neighbors WiFi and signal?
N Nees Well-Known Member Joined Oct 21, 2016 Messages 138 Reaction score 4 May 1, 2019 #5 I am very technically minded when it comes to WiFi
Thor Honorary Master Joined Jun 5, 2014 Messages 44,413 Reaction score 7,522 Location Bellville May 1, 2019 #6 If you want to use your neighbor's wifi then you need a CPE, get a Mikrotik Metal AC and 6dBI antenna (normally comes with it) Otherwise look for the TP-link or Tenda CPE units they launched recently
