So i have a setup (Which i will explain below), whereby i have the same SSID for all the APs. The problem is when there is a power failure then the other repeaters attempt to connect to each other first and lose internet connection as it seems the primary router (Whereby my fibre connection connects) takes some time to power up and the other 2 routers power up and attempt to connect to each other hence receiving no connection.
Internet: Fibre connected to primary router
2 x APs: connect to primary router via repeater mode to original SSID
APs SSID: broadcast original SSID
Objective: Property is large and need to conenct wifi cameras to internet for remote viewing. I also dont want to keep changing SSIDs and passwords on mobile devices hence i want to be able to walk anywhere in property without losing connection.
If the power stays on then everything remains stable and works perfectly. The only issue i see is when the power fails this is likely what is happening as i cant connect to the APs afterwards unless i power them off and on again. An alternative way around it is to obviously have a UPS for the main router and fibre so the power never dies, however i would like to try resolve it from a software point of view if possible.
