Will Giga work on B593s-601 ?
nicroets
Tbilisi, Georgia
I bought my LTE router from Telkom, but now I want so switch to Cell C. Will it work ?
Can I buy a prepaid sim for testing before I buy the Giga ? I assume I must disable roaming.
Hi nicroets
Yes, it will work however you will need to do a dial up connection. Shout should you need assistance with that.
^SM
The B593 does not have a dial up option. So went to the shop to get a SIM for testing. They gave me one for free with R10 airtime :D
I have good LTE signal strength with 5Mbps downloads :D
