InternetSwag
I'm upgrading my GPU soon, but it'll take a few months of saving to afford a new CPU.
I have an i3 2120 3.3 ghz.
Showoff! My cpu is a core 2 duo I can't even play nfs the run.
Are you sure it's your CPU thats at blame. I play The Run on my old dual core....
To Sokkie and Internetswag - as long as you have a dual core or higher CPU ( c2d+ ) you can run any game,what WILL however hold you back is your RAM and most importantly your graphics card - it's the difference between running 2 FPS and 40FPS
I use the old 9400 GT and 3gb of ram.
Sokkie dans, it's your 9400gt that's holding you back.
I'll check computer corp thanks.A 560TI or a 6770 will do you MAJOR improvement without breaking the bank
Guys come on guys but I played mw3 on this baby. Which gpu do you recommend then?. I can spend R800 I'm not a hard core gamer.
It's fineI recently also upgraded my pc - it's quite a mission upgrading because you need to replace everything cause nothing is compatible anymore.
for what it's worth I'm looking at spending about R2000-2500 on my new GPU.
