kaspaas
Hi,
I regularly go to construction sites in the sticks (new mines not buildings) dragging my Fujitsu Siemens Amilo Pro V2030 along - I'm not taking a super machine to those terrible dusty conditions.
The problem is that many of these sites provide WiFi connectivity (open security), but the signal is usually not that great. The reason for this is usually that one is more than 200m from the access point antenna, or one is inside a converted container which only allows signals to enter via the windows and doors.
My laptop does not have a connector for an external antenna.
I'm now considering an USB WiFi unit like http://www.miro.co.za/detail.php?cat=13&sub=54&id=5189
but need some expert advice as this is a topic I know very little about.
Will such a unit improve things, or is the laptop's internal WiFi radio/antenna setup already better than the external units?
Any other advice on improving WiFi connectivity under these conditions? It is not very practical to turn one's computer until the bit of signal that is available is optimal.
