If that's your question, you shouldn't be dispensing advice... A 64 bit Windows would refuse to install if he had a 32 bit CPU - nearly all mainstream CPU's made in the last 14 years are 64 bit.What chip do your PC have
I have followed the instructions to change my OS to 64bit. All goes fine, I reboot etc., but when I check in Control Panel, OS is still x86(32bit).
All data is on a 32Gb USB drive.
What am I doing wrong?
Regards, Ken
You must be reinstalling the 32-bit version. What size is the ISO that you downloaded?Information as per Microsoft website. I've created the x64 data, and when I change the Bios to read from the USB, everything is fine. I followed the prompts to INSTALL, and the process appears to go well. At the end, I'm asked to reboot, which I do. Then, the whole INSTALL business starts again... Vicious circle![]()
Restart.OK, so once I have set the Bios, what do I do from then on?
There is no upgrade to 64bit from 32bit,thats a misleading statement to call it UpgradeYippee, now have a Win10 Pro on 64bit!
Sadly tho, apart from my desktop pic, everything else is missing. Prior to all this upgrade stuff I Cloned my drive using Macrium Relfect. Any chance I can get some of my items back?
