hyperian
- Apr 17, 2008
Like a fool I managed to pull off my D-Link 2640u wireless ADSL router's antenna (I thought it might have an RP connector). Needless to say, the router no longer transmits a wireless signal with any strength to speak of.
Instead of buying a new wireless router I thought of getting a wireless access point so that I can restore wireless connectivity at home, and get a better signal distribution (where the router is isn't where most of the wireless devices are - so there's mostly a weak signal).
Will this work? As far as I understand, all that I would need to do is connect the router to the access point using a LAN cable. Can anyone recommend any decently priced (+- R 400.00) wireless access points?
Thanks!
Thanks!
