Hi Surv0,
The Telkom ADSL Premium Combo Wireless Modem is meant to support 4(RJ-45) ethernet connections as well as several wireless(802.11g) machines through a single ADSL line.
I have two machines linked up to the router over ethernet, which works fine, the routers DHCP Server assigns them each IP address's and seems to be fully functional.
Yesterday, when I tried to connect to the internet via a laptop over wifi, It established fine the first few times, but whenever I tried to access the internet, It took forever, or just hung. I noticed that I could easily access the routers webpage from the laptop(over wifi), but whenever I tried external webpages - nothing. I checked the other 2 machines, but they were working perfectly.
So I went to the website:
http://www.marconisa.co.za/premium_combo_software_download.htm, and downloaded the new firmware - which was meant to 'Improve wireless/WiFi setting' and low and behold, after installing the firmware the router's dhcp server no longer seems to gives out IP Addresses to the wifi machines!( No IP Address could be assigned - limited network access-blah).
I've been checking the firewall settings - but there only seems to be a firewall from wan-lan (which seems to work) and not wan-wlan or router-wlan or whatever.
I've checked the security settings several times and tried to connect from different OS's and Latops, but no I haven't really messed around with different security methods other than WPA-Passkey TKIP (Due to having tremendous trouble getting other security settings to work well with OS X - I will try and change this though - thanks for the tip)
It does seem like a crummy router, but odd that the wireless just fried up (Seeing that it was 1/2 working to the router - but not to external sites)?? I am especially surprised by the software running on the router which is insanely confusing. It seems to complicate the most trivial things. My feeling is that it is a bug on the router software side created by a confused programmer.
Anyway, was just hoping for a quick fix. In the interim, I have taken my old wireless router and slapped it on one of the ethernet connections. And then disabled the wireless on the Telkom router (12th option down on the Wireless Configuration page, just below the default Transmit Key option??? - Crazy).
If anyone has managed to get one of these guys to work, I would really appreciate how its done.
