Wireless Adsl Router (Bridge & PPPOE)
Bobb
Chicago
Hi Guys
Can any of you recommend an ADSL router that will do bridge, and PPPOE simultaneously? I want to set the router to auth an account, and i want to be able to bridge at the same time from another machine... any ideas which routers would allow this?
Netgear DG834UK v3 or newer with latest firmware - only router I use and does this exactly :)
Cool, Now i just need find a dealer that does netgear here in Durbs... other than Axiz.
I wonder if the Billion BiPAC 7300G would do it? Thats more commonly available at the moment :)
Honestly Dunno :P Where's Mr billion support when u need him
We call This:PPPOE WITH PASSTHROUGH.
This allows Multiple PPP connections on remote hosts.
The new 7300RA, 7300GRA, 7300N, 7300GXL and more supprorts this Function.
i have a 7300RA and would like to know how i can set this up. I have been unable to find the specific setting. I also had to phone in to the call center to find out where i can download the latest firmware for the 7300RA.
To be honest i would not recommend billion after my experience with them.
Regards
-midkemia-
Firmware version 1.06d supports this Protocol.Available from our ftp server and forwarded to youre mailbox
To change to PPPOE with passthrough go to:
Advanced>>Configiration>>Wan>>Wan Profile>>Change the protocol to PPPOE with passthrough
Regards
-midkemia-
I can't believe you had a bad experience with the Billion Support desk, any time I have had to deal with them they have been great and nothing but helpful.
Maybe don't judge them after just one bad experience.
