Wireless antenna
Dolby
Someone snapped my antenna off my Linksys PCI card ... is it possible to get just a card? I f so, do you know what the is?
Ummm, is it that the antenna got snapped off (and maybe taken, but either way is no longer joined and therefore useless to you/the card) or is that you have a perfectly working antenna and need a new card with which to pair said li'l antenna? :D ..and what "the is" might that be? :rolleyes: (but, pisstake aside, do you mean that you're actually after only an antenna with the right kind of SMA connector?)
My bad ;)
Was typing that quickly on my phone before getting into my area where 3G has been dead for days :(
bdt - you're right with the statement : the person snapped the antenna off the card leaving only the base of the antenna plugged in and the actual anteanna on the floor :/ I tried to put them together again, but the wire that runs through the centre is snapped.
So yea - I'd need a new antenna to stick in my card that works perfectly ;)
What I also tried asking is - if that is possible - does anyone know what I'd pay?
Also, how many different connectors are there?
Yup, that'd break it all right - mayhap you should consider giving the miscreant an antenna suppository...? :rolleyes:
OK, some good news here: you now qualify for the super-monster-penislike-extension that is the 9dBi dipole, with hot SMA-male reverse polarity action... :D
The Miro retail price list has an RRP of R144 for that monster - not bad for getting a nigh-on footlong talking point on the back of your PC!
More than you ever wanted to know about RF connectors right here!
Ok - thanks bdt!
Can the public buy from Miro ... ? The Miro site - for some reason - is blocked here!
hehe - yea ... but 3 routers down the line, 2 dongles later and a new OS and it all seemes to work now ;) The main thing seemed to be the OS ...
Anyway - wanna sell this, so I need a cheap antenna. I think it comes with 6db
