aka.Goliath
I have tried to find some info on this but no luck so I’m now asking all of you. I have a D-link DWA-556 PCI-e wireless card that has 3 antennas which I thought would be able to fix my connectivity problem. But it doesn’t, the problem being the reinforced concrete wall between my pc and the router 20m away. I want to know whether an extended antenna would make a difference and whether I need to get 3 or would only 1 be ok? Secondly should the larger antenna go onto the router (netgear wireless n) or my wireless card?
