snobee
Hi there,
Using any SOHO type wireless Access point or wireless Router, you are able to select a channel. Now are channels all that important?
Is there any particular channels for SA, as I have noticed that one particular router offerered me channel 11 when I selected "Africa" in the channel settings?
Also, what if you have multiple wireless devices with the same SSID that are spread out for better coverage. Should they all have the same channel?
