ok I just moved into my new house and I need a bit of help deciding on what set up to get.
Fiber is a 1000mb down.
old place was very small so we only have a single router that handles the wifi.
Fiber box is in a very award spot in the lounge.
Lounge, dining room and kitchen has great coverage.
walls are thick, so bedroom that is about 10m away from router has no coverage, walls are thick.
main bedroom that is 5m away in a straight line also has poor signal because of thick walls.
office is in the opposite direction to the bedrooms and has decent coverage, but there will need to be 1 lan port for a PC there.
I was thiking about the DECO S7 3 pack.
replace router with one.
one in the office area.
one in the bedroom area.
do I need to run CAt5 between the units or do they pick each other up?
can I run a lan cable from the office unit to the PC there? lan connection is work security requirement for some ungodly reason so a wifi 6 dongle in the PC is not an option
Advice is appetited.
