Wireless networks will never be infallible to intrusion. However difficult it may become, it is simply not 100% secure. The best we can do is implement better security installations between the connection and authentication stages and to make use of better security protocols- regular authentication and privilege audits, regular encryption key changes, etc
Quite true. If the signal can be detected someone is bound to try and hack it.
Wireless networks certainly makes life easier to a certain extent because no cable needs to be laid to connect more work stations onto the network. But as usual a bit of common sense with repect to security is essential.
Installation +1. Security -10.Unfortunately some businesses with high-risk data are very paranoid when it comes to wireless networking, even if all possible precautions are taken.
Initally my boss didn't even want a network at all (wired or otherwise) because of the potential risks of viruses spreading from an infected machine to all others. But eventually I managed to persuade him and we now have a wireless network. I have stepped up security with the move from WEP to WPA and using the maximum length password (I think it is 64 characters) generated by KeePass Portable using letters/numbers/symbols.
You can't be too careful with security and I am currently working on machine to run Smoothwall on. Hopefully I can get it to do all the things I want.
Personally I think wireless networks are generally more secure than wired ones. Why do I say that? Well firstly I don't know many people that implement MAC address filtering on their wired networks but its quite common to implement it on a wireless network. Sure a wired network requires a physical barrier penetration whereas the wireless network allows for remote attackability. But whats stopping most guests from walking in, plugging in their laptop and snooping around?
I'd be intrigued to hear what measures people in this forum take on both wired and wireless networks.
Personally I use MAC address filtering, statically DHCP assigned addresses, computer certificates, WPA2 encryption using machine generated long keys and some IDS processes running to keep things in check.
I've thought about deploying IPsec for all Windows machines but haven't been brave enough to attempt it yet.
What about you?
The best you can do in terms of keywords is to use symbols such as % @ (shift+number). Using this and the other alphanumeric keys gives a possible 64^94 possibilities (assuming you use 64 characters). Simply using a good antivirus across intranetworks should stop a virus in its tracks before it can do any harm.
same thing with satellite traffic, put the card promiscuous mode and run a filter....very interesting. Implement proper security and key changes every once in a while and it's as safe as it is going to beI know several WISP's that don't apply ANY security whatsoever on their networks, apart from MAC filtering, which is trivial to bypass. If only their clients know how exposed their vital info are ...
For most people that's the best they can do. Even better, use a hidden SSID. Works well for me.
never tried that one . still want to try a pgp vpn sometime
pgp vpn? WTF? Hidden SSID is a standard option on Access points and adsl routers.
my bad got mixed up.![]()
