Wireless USB adaptor
hashbrown99
East Rand
My onboard LAN port died so want to connect wirelessly to the internet via USB rather than replace an entire mobo
Any recommendations? I see a lot of people recommend the TP Link stuff but no clue where/what to buy. Would prefer retail or else very quick online ordering and delivery
Network will need to cover a 4 bedroom house where the router is basically in the middle of the rooms that will be used.
Any advice or recommendations welcome
From Uniterm Direct:
TP-LINK WN822N 300M Wireless High Gain USB Adapter
Bought a router from them, service is great
Thanks - definitely worth a look
Got one of these in a pc here: http://www.dbg.co.za/product_info.php?cPath=1_55_63&products_id=708
It is pretty decent, but we also have one of these on a laptop: http://www.dbg.co.za/product_info.php?cPath=1_55_63&products_id=691
Both run pretty well, no issues with either.
No coment on the software though as I never installed it and just let windows handle the wireless config.
thanks - is either of these pcs running on Win7 64bit?
How long is the cable that comes with it? I would prefer to plug it in at the rear of the case as that is where the majority of my USB ports are.
http://www.totolink.net/ find product N150UA Wireless USB Adapter
Bought 2 of these in Windhoek - R95 each
Work flawlessly on my Win 7 and Linux setup
Comes with a wired USB dock to extend the reach of adapter
Don't know who stock them in SA
