Just want to make sure I am not behind in the technology times
??Just realise in the eyes of many, if you choose to follow our advice, you are joining the ranks of the technology "refuseniks" and will be treated as if you are a "dinosaur" ...:twisted:
Wired is faaaaar better than wireless.
I'll give you an example.
I recently got an IP camera and connected it to a wireless bridge.
I then connected the camera to my network via WIFI.
As I was stream the live content from the camera on my laptop, I was streaming an episode from my local network from Plex via wifi as well.
My network suffered because of this and the episode was buffering up until I killed the stream from my CCTV camera.
Wired is the best approach to the above scenario and keep wireless for your mobile devices.
Would something like this happen over say a 5Ghz - MU-MIMO?
Hi
With all the options available for wireless connectivity, would you still recommend a cabled connection to an access point to extend your wireless signal?
This was on my local network.Sounds more like a bandwidth problem.
Modern wireless should outclass 100mbit for everything but latency.
Gigabit is a different story, but sounds like your wireless isn't up to scratch.
But in general I dislike this blanket wired vs wireless business.
There is wireless, then there is wireless and then there is yet more wireless.
There's good wireless and then there is **** wireless
Then there's also people sitting at 10% signal and then claiming wireless is bad. No, it's not, you are just doing it wrong.
I fully understand that.
You still haven't listed your equipment or listed ranges and signal strengths etc.
There are many more variables to wireless than "is it on".
Oh, sorry.
It's a DLink DSL2750U providing wifi to the below:
a HikVision 2042 connected to a wireless Bridge (DLink dap 1155),
and an LG-LM6710.
Reception is good between the above mentioned.
While GoT was stuttering, I closed the browser that was streaming the CCTV content and the episode was playing smoothly again.
