Word to Excel conversion
getafix33
Hi
I am trying to print labels and the only template that I can work with is in .docx format.
I have an Excel spreadsheet with data comprised of various formulas etc.
I have tried online conversion tools to convert to PDF then to Excel but no joy.
How would I create an Excel spreadsheet based on the Word template?
Here is the Tower W110 Word Template.
Thanks in advance
Select the spreadsheet as source. Shouldn't it be the Word doc (template) as the source?
No unless I misunderstood. You open word and go into mailmerge wizard. Then select the template for your lables, Then select your data source as the excel spreadsheet and build the lable with the fields you want.
This doc I made was to merge with outlook but just select the label. - so ignore anything email-related. But the process is similar.
I am on my phone so wont open your link.
Not sure what you want to do. You say you have an excel with formulas and data.
And then you say you convert to pdf then to excel?
Here is more relevant info
Find your excel file and choose the records you want
Position the fields you want to use on one label.
When the first label is right, click update labels
I always merge to a blank document and then print that - if something goes wrong you can start at a particular point without having to do it all over again - and you don't waste labels.
Hope this helps
