Workaround for cell c disconnect problem for linux
leojay18
Hi all
I came across a workaround solution for the cell c disconnect problem. Here is a link to that post.
A workaround for this problem has been suggested for Windows. Details described at Link 1 & Link 2.
Can one try this for linux? If so, how?
While I'm running "ping www.google.co.za" in terminal I don't get any disconnects from cell c 3g, so it seems like it might be working. I'll have to still test it more though, also with/without pinging.
