CranialBlaze
- Jan 24, 2008
For some strange reason my DVD-Writer does not write DVD’s/CD’s when used in my own computer, so far I have tried everything I can think of.
Relevant specs include a Maximus 2 (Latest BIOS), Q8400, 4GB Corsair, Samsung SATA Writer, Win7 Ultimate X64.
So far I have tried:
Using a friends writer, it also does not write disks in my box, it was a Liteon.
Using my writer in another computer, then it works.
Swapping SATA cables and ports.
Updating Drive Firmware.
Changing writer software, I have tried, Nero 8 and 9, Ashampoo Burning Rom 9, Itunes (burning a music CD), Windows built in writer.
Since this problem started I have formatted my drive twice, first time I went from MS Retail Release to RTWin Customized Nvidia Edition, and when purchasing a new drive last week I switched to the ATI edition of RTWin as I recently upgraded my 8800GT to a 4870. I have been using 64Bit windows since before I bought this writer, so I assume the 64Bit can’t be the cause, I have tried writing disk with an without all windows updates being installed, all my drivers are up-to-date.
The exact nature of the problem I such, on both writers that I tested and in the software that shows the buffer fills up to the max and it indicates that the burn process has begun, the progress bar however does not move at all, after about 6 minutes I get a generic failed message, I have tried different brands of disks and writing at different speeds, yet no matter what I try the disk always fails. Looking at the disk itself it appears to of written about 20%, but the disk itself is unreadable.
I am hoping you have some suggestion that I could try as it’s pretty obvious that a new writer won’t solve the problem, I updated the board firmware after the problem started thinking maybe that would fix it, it’s an 850W RealPower PSU so power is an unlikely cause, I tried numerous SATA Ports so I have all but ruled out the board as the actual cause, the SATA cable is free and clear as when testing my writer in the other computer I took the cable along and have tried a different cable inside my computer as well, the problem began before the custom windows so if anything that should of fixed the problem. The drive is now connected to the SATA port and Cable that was occupied by my HDD before I moved it to my other computer so it can be used as a media server.
As for reading the drive works perfectly, I get full speed uncorrupted copies off the disk.
