xbox 360 on LCD -Audio?
Bmalcombb
Hi guys
i run my 360 through my 20" samsung LCD monitor
i use my pc for audio as my monitor does not have its own audio
my problem is that when i want to take my screen and xbox to a mates house i have no audio.
is there a solution to this problem or do i have to lug my pc with me everytime
your help would be appreciated
Other than spending a lot on specialised Xbox headphones the easiest way to do this is to get a cable that goes from the L/R RCA to female headphone jack. Then plug a cheap'n'nasty set of desktop speakers with headphone support into that and you're away
You could plug headphones straight into L/R RCA to Female headphone jack but the sound is low as it isn't ampified. On my pc's xbox I have it plugged into the pc's line in and that works well.
Yeah hence the reason for the desktop speakers.
On a Xbox?
um no, i was thinking sticking it into a toaster why an xbox :D, we are talking about a xbox without sound so that is what i am asking if you can stick it into the usb...
do ure monitor have audio out? if yes, then find ureself pc speakers u can pop into there.
this
thanks fudzy
will try that option first as it is the cheapest:D
i just need it for when i jam at friends places
so doesnt need to be great
i run it through my pc at home so im sorted in that department
shot
