Yellow stain on secondhand car engine
elL0L
Belville
Hi,
I was hoping to find an answer here.
I'm looking to buy a secondhand car, but I looked inside the engine and saw this:
Looks like an oil leak to me?
Hi,
oil leak wont be inside the bolt top unless it sprays out .no it looks like wax spray which is sprayed on as a protector sometimes and hasnt been cleaned off before running the engine hot .
Hi,
Looks like Tectyl rust preventer spray, though that is a weird place to spray it, is it like a sticky oily substance?
Try spraying some brake cleaner and wiping off then monitoring for oil leaks
Also is your accessory belt on the wrong way around ?
the belt is coming around the alternator from underneath then over the top to the aircon pulley on the right .where you can see the ribs is a balancer or tensioner maybe, flat pulley surface
