Howzit,
So recently bought a place, which had a dish up already and a single LNB there were two cables though. One into the single LNB and the other one chopped off.
In the lounge there are 3 cables on from the wall socket and 1 cable in the main bedroom.
I couldnt get it to work with the single LNB, I got a neighbor to test it and nor could they get it to work.
So went out and bought a dual LNB and a 1.2m coaxial cable. I extended the chopped off one with the one I purchased and then placed the dual LNB it its socket and screwed both cables in.
I have tested all 3 cables in every possible way and still it tells me no connection to the LNBs.
I will get into the ceiling tomorrow to follow said cables.
What else could be wrong? Alignment?
Regards
Toitjie
Regards
Toitjie
